Old 03-30-2010, 07:35 PM
dlotz dlotz is offline
Default Voltage regulator connection question
So
from the ERA website the diagram show the "I" terminal going to the ignition light.
Is this a positive or a negative feed? I tried to wire it directly to he light and I can't get the light to come on. I had the light running to the IGN key switch and it worked but now I can't get it to light up.
I looks like it should be the ground feed to the light, right?
Is the 15ohm shunt needed?
