Old 03-31-2010, 04:24 PM
07cob's Avatar
07cob 07cob is offline
Cameron
As Merv mentioned, I also had a similar issue in getting my engine started.
When you switch the ignition on, can you hear the fuel pump run (even if just for a couple of seconds)? This was a tell-tale for mine. I had missed an earth connection and the ECU would not fire up the pump. Missing earths can cause no end of difficulty identifying problems.
Do you have easy access to the ECU? If so, it would be good to disconnect the big plug and check pins 20, 40, 60 and 49 for earth connections.
Geof
