Old 03-31-2010, 06:36 PM
cameron02 cameron02 is offline
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
Well I put it all back together and of course I tried to start it (just in case the elves had fixed it over night) but no luck. I found a couple of earths in the engine bay and removed sanded back and reinstalled still no luck. I will keep looking.
Geof 07Cob.......Thanks I will check those pins.....hang on a sec....how do I check/test them, or am I just making sure the connectors are there?
Yep the fuel pump is pumping fuel although if the pressure isnt high enough it could be a problem, I'm not able to check that at present.
Merv...........I think I might take you up on that offer of photo's. I'm gunna need all the help I can get
Cameron
