  #40 (permalink)
Old 03-31-2010, 07:44 PM
madmaxx madmaxx is offline
get on scof. there is canceling cam in the steering column for the turn signal, set screw may be loose. Use fishing line to remove the steering wheel cap, do not use a screwdrive or knife you will scratch the steering wheel. Once removed remove the nut holding the steering wheel on. you will see the turn signal mechanism. you will see how it works.
