Originally Posted by cameron02
.....hang on a sec....how do I check/test them, or am I just making sure the connectors are there?
Cameron
Similar to the way you used your light meter to check the injectors. Connect one end of the light meter to the positive side of the battery (maybe with a cable extension) and the other to the pins in the connector (not the ECU!) - numbers 20, 40, 60 and 49. If these connections are earthed, then the test light will glow. If not, you will need to trace the wire (physically) and find where the earth connetction is missing.
A multimeter would be a little easier but if you don't have one this should work just as well.
Geof
