  #24 (permalink)
Old 04-01-2010, 11:16 AM
madmaxx madmaxx is offline
Thanks Greg. You are right I was talking to our Mobil representative about my boat with flat tappets and asked about the additives. Their response was anything under 1K miles or less than 50 hour on a boat and you can use any oil. The additives deplete overtime, and you get no advantage starting with more additives except the additives are in the oil longer. If you are changing every 1K miles you will always be adequate protected if you are going 10K mile between oil changes with out roller lifters you need a different oil or an additive package.
Mobil 1 10W30 at walmart is $23.50 for 5 quarts, my system holds 8 so for $50 per year I'll use the synthetic for grins, heck I spent $13.00 at lunch today. I think most use an oil much to heavy such as 20W50 when they should be using 10W30 I also feel most run their engine way to cool at 170F on coolant temperature.
That being said my boat has a 140F thermostat since it is sea water cooled, 20 years old, first oil change is when filter rusted through at 7 years. It has over 1500 hours and will be on the lake this weekend. It amazes me the block has not corroded through. I start it and full throttle revers to pull it off the trailer, so I question if abusing a cold engine has any determental effects, I am sure it does but are they measurable.
