04-01-2010, 02:08 PM
CA
Cobra Make, Engine: ERA 707, 446ci FE
- Thoroughly lube the cable - use a good silicone-based lube.
- Try to pull any sharp bends out by tying the cable to support points.
- Get a longer cable if you can so that the bends can be made into fewer and larger radiuses.
- When all else fails, go to an electronic speedo...
= Si Opus Quadratum vis, angulos praecidere noli. =
