  #48 (permalink)
Old 04-01-2010, 03:26 PM
cameron02 cameron02 is offline
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
Hey Stephen....No the wiring is still the full AUII loom (one mouse a couple of pidgeons but no rats) but I relocated the wiring through the trans tunnel before painting so it looks a lot better now. But yes, a pain to work on. One of the reasons I did not remove any wiring is because I thought I would stuff something, also I still have the original cruise control unit which I may connect (just plugs straight into existing loom) up one day if I can be bothered working out how to make and connect switches for it.
Merv....When you say fuse are you talking about a fuse in the fuse panel or a fuse in the computer. Yes I know I have spark because the motor runs if I spray some carby cleaner through a vacume port, so I'm pretty darn sure its fuel related. I bought a CHEAP multi meter last night. How do I use that sucker to test stuff? Positive to the wire/pin I'm testing and negative to the body/earth? I guess auxillaries on.
I will try to post some pics in a seperate post
Cameron
