Old 04-02-2010, 08:25 PM
mickmate's Avatar
mickmate mickmate is offline
That's a good shot of Sals, I'll have to look up a few more. So you see he has a LeMans carb with the tube between float bowls but it's on the opposite side to the fuel feed lines from the log. That brass fitting is the 45 that goes from the flare end to the NPT. The line you'll get will either need twisting to match the tee or the first bend cutting off and I used a tube nut and sleeve to go straight onto the tee. I'll get some pics without the expansion tank in the way.
mickmate
http://www.actoncustom.com/
