FE coil mount on 2 x 4 intake
What type of bracket is being used on the dual quad intake or block to mount the coil and where? I'm having a hard time seeing a coil in most of the pictures I find. I've seen single bolt coil brackets (for a Mustang I believe) and two-bolt coil bracets.
I found one picture that looked like the coil was partly hidden under plug wires on the front driver side of the intake. Can't see the bracket clearly however.
