Old 04-04-2010, 07:41 AM
dcdoug's Avatar
dcdoug dcdoug is offline
Originally Posted by psychoSEAL View Post
Rick, The inner cable can be moved in and out about an inch or so. I am sure it is going into the housing attachmnt on the gauge. I will check to see if the inner cable rotates when driving. It was working fine until I reinstalled the gauge and cable. Has me stumped. I will let you know. THANKS for your help.
I had the same problem at one point. Make sure it is full seating into the driven gear that plugs into the transmission. I can feel like it goes in, when it doesn't (the cable just pushes back up into the cable sheath. Push it lightly until you feel it go into the gear.
www.partskeeper.com
