Old 04-04-2010, 06:38 PM
kayakjack's Avatar
kayakjack kayakjack is offline
Ray,
I wonder if the sounds coming when you were in 5th gear could have been due to low fluid level in the transmission? You drained and filled. The old stuff looked fine. You filled with good stuff. I assume there was good stuff in it before. If it was low and is now full, maybe that (low fluid level)would cause the symptom and provide the cure (proper fluid level).
Jack
