Old 04-05-2010, 07:37 AM
JCoop's Avatar
JCoop JCoop is offline
Cobra Make, Engine: Superformance, FRP460 Big Block
Originally Posted by kayakjack View Post
Ray,
I wonder if the sounds coming when you were in 5th gear could have been due to low fluid level in the transmission? You drained and filled. The old stuff looked fine. You filled with good stuff. I assume there was good stuff in it before. If it was low and is now full, maybe that (low fluid level)would cause the symptom and provide the cure (proper fluid level).
Jack
Could be, Jack. Unfortunately, the old oil went straight to a drain pan with a lot of other gunk. Couldn't really measure. Old tranny oil looked almost exactly like the new stuff I was putting in (liquid gold).
Not sure if groaning is a known symptom of low tranny fluid in a Tremec. Maybe the tranny gurus can verify? I was pretty convinced it was the rear end judging from the directional "feel"; especially since I've had the top up until last Friday...
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
