Originally Posted by JCoop
MM, I would have gone with the 75W140 too, which, I think I will do after I install a drain plug as recommended at SCOF. The oil that's in there now will be an expensive flush, as I really couldn't suck all the old oil with a hand pump.
But, that would be a midsummer doldrums kind of project...
Ray,
I took a look at the instructions on SCOF for drilling/tapping the rear end for a drain plug. It looks like a nice upgrade and would make the job a lot easier.
Have you ever run across any info regarding a basic recommendation regarding the miles between rear end fluid changes for a car that is only driven on the street? I'm guessing that it's similar to the maintenance requirements for the trans fluid.
Doug
