Old 04-05-2010, 09:49 AM
tgitchel tgitchel is offline
Cobra Make, Engine: ERA #776, 445 FE
Thanks for the reply, Bob.
I did open the upper right-hand fitting and didn't notice any bubbles comming out. I tried "burping" the system by squeezing the water hoses. I will jack up the front and remove intake sensor as suggested and try some more. Also, I have one hole in the thermostat as per the recomendation that I saw in the ERA manual. Pretty sure it is installed correctly, but I will check that if other suggestions don't help.
Yes, MSD distributor. Any ideas on the tach not working? Hard to know for sure on the timing without a good RPM reading.
Thanks,
Tim
