Old 04-05-2010, 11:37 AM
tgitchel tgitchel is offline
Cobra Make, Engine: ERA #776, 445 FE
Originally Posted by strictlypersonl View Post
If your engine (cam, probably) needs breaking in at 2200 rpm for a prolonged period, I would augment the engine fan with an external one. You're generating more heat than usual, first from the higher rpm, second from what is most likely a tight engine.
Your tach should work OK with a wire directly from the MSD tach output to the signal side (not the green-wire side) of the tachometer.
Yes, I was trying to maintain 2,200 RPM for 30 min total with the break in oil before letting it idle for the first time.
Should I leave the orange wire at ERA harness #40 connected to the white wire of the MSD, or disconnect and just have the wire from the MSD tach output going directly to the signal side of the tach?
