Old 04-05-2010, 11:34 AM
DougD's Avatar
DougD DougD is offline
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
Originally Posted by Bobcat View Post
DanEC , don`t kn ow how accurate you are trying to be , but Ford originally bolted the coil to the front of the driver side head as the others have said , but used the bracket that held the fuel filter/can as a stop/locator . The original bracket had a little tab on it that acted as a stop against the fuel filter bracket . My Galaxie is that way and every 427 I`ve seen is also set up like that . I know Donahue Collector Cars in FL has those brackets . The thing you would need to check is coil diameter vs the I.D. of the bracket as some of the aftermarket coils are a different diameter than the original . Most are bigger and will work ... the smaller ones cause a problem .
Bob
Do you have a pic of that bracket you could post?
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
