Thread: Balancing
Old 04-07-2010, 12:14 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Originally Posted by Gunner View Post
Glad it worked for you, but I'd never have a daily driver balanced this way, much less something lightweight and intended to be driven fast.
That used to be the way to balance tires on motorcycles. That was the step above bubble balancers and at the time there were few spin balancers that could take a bike wheel. The only thing I had concerns about were some of the items you don't seem to feel are an issue. Maybe on a car, but on a bike, bearings( they are predominantly ball and not tapered roller) can create vibration issues. So I was never thrilled with them because I felt that unless you had a new tire installed and could check the bearings, you could be masking a potentially serious problem. That may be one reason that the rears wouldn't be done by the balancer. He knew that all the CVs as well as differential components could trigger a vibration. These used a strobe light though, I'm not sure about the "feeling" the vibrations....probably take a better feel than I've got...and it's pretty good.
WDZ
