Old 04-08-2010, 06:56 AM
pusherfans pusherfans is offline
Default Holley - Bad Run Of Carbs
I just wanted to let everyone know that if you bought you Holley carb in the past year sometime, check the finish on it. If you see signs of corrosion or the plating peeling, call Holley Tech Service (270-781-9741), it may be part of a bad run and they will replace it for free. They will need your list number and date code: http://www.holley.com/TechService/ListNumber.asp
Edit 4-8-2010 10:56 EST: I spoke with Holley again and this issue is from 2005-2006, so I guess my carb was "NOS" since it was purchased last year....
