Old 04-08-2010, 11:09 AM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
D -- Greetings, some notes ;
1. There should not be a wire between the Dist and the coils --
2. In an MSD setup the only wires attached the coil leads should be from the MSD.
3. The TACH lead in the MSD should be grey I thought.
4. I cannot see the detail of where and how your *A* terminal is wired from the VR to the rest of the system.
5. the *I* terminal on the starter solenoid can be used to feed things as it is just a "Lug" for 18-22 gauge wire.
you can have an ignition relay feed the I terminal and use it to feed things like electric chokes, MSD switched on leads, or >?
a larger drawing with the relays and their connections outlined would be helpful!
hope this helps.
Steve
