Old 04-09-2010, 04:57 PM
ERA Chas ERA Chas is offline
Originally Posted by Dangerous Doug View Post
I assume by "hips" you're referring to the rear fenderwell turnout just behind the door. That area gets sprayed by road debris by the front tires.
On the nose, are you referring to the area between the headlights up to the front edge of the hood?
DD
Depending how anal you are: all the above plus the bottom curve behind the rear wheels. The headlights on down to the bottom edge, all across the front and scoop area. The parking light area takes a beating around to the wheel arch. I might leave the radiator inlet alone and not go up to the hood-but it does get sprayed. I've got chips on the hood scoop leading edge and surely the windshield. Those are 100+MPH rocks coming at you...
Chas.
