Old 04-09-2010, 09:49 PM
Trueoo7 Trueoo7 is offline
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
When I rerouted my clutch line I went to Home Depot and bought about 10' of #6 grounding wire (green insulation) which is about the same size as the tubing. Then I bent it into position in the car. Its fairly rigid and will hold its shape so you can remove it and use it as a template to get the tubing very close to what you need. You may have to tweak the tubing a little by hand when you get it in the car but it worked great for me. I also painted it black so it blends right in, over the footbox and along the firewall.
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
