Old 04-12-2010, 04:06 PM
maxum_101 maxum_101 is offline
ok i tried the spring to return the fork, spring is not strong enough to pull it back, tried many springs , i just cant see why it needs so much pressure to pull the fork back, my bearing is always running on the pp. my only other option is to remove the internal spring.
now 1 more question, i have bled the dammm thing at least 50 times, ill even pull the fork all the way back and then tighten up the bleed screw, and all is fine, slave does not push out at all, ( it stays bottomed out) press the clutch and it goes right back to where it was before, WHAT GIVES???
