Thread: Vanishing Sea
Old 04-12-2010, 05:55 PM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
Originally Posted by Sharroll Celby View Post
Actually, most of the Los Angeles area of Southern California is best described as a "Mediterranean" climate, NOT, as you incorrectly posted, a "scrub desert."
Mediterranean is more a description of climate than geography. You'll note that most areas of the Med are scrubby, sandy territory that's not terribly arable or fertile. Cultivation in Italy and Greece is largely olive trees because they're extremely hardy and don't require irrigation in most years. Also consider the entire top of Africa, which is "Mediterranean." Most of the area is not some lush resort jungle, or anything like it.
A map of underlying geography and ecology shows that the LA Basin has a few arable regions, but can fairly be described as a scrub desert, chaparral or similar low-water, hardy-growth zone. It doesn't have one tenth the water it needs for its population and never did; IMVHO squatter's rights don't entitle it to half the water in the Western US.
Those vast stretches of desert north of the Grapevine - you know, the ones posted with b*tch signs every mile or so - are even less naturally arable and have an even lesser right to someone else's water.
I might change my mind the next time I fly over and see a lot more native-plant landscaping and a lot fewer pools.
= Si Opus Quadratum vis, angulos praecidere noli. =
