Old 04-12-2010, 06:52 PM
jhv48 jhv48 is offline
Originally Posted by maxum_101 View Post
ok i tried the spring to return the fork, spring is not strong enough to pull it back, tried many springs , i just cant see why it needs so much pressure to pull the fork back, my bearing is always running on the pp. my only other option is to remove the internal spring.
now 1 more question, i have bled the dammm thing at least 50 times, ill even pull the fork all the way back and then tighten up the bleed screw, and all is fine, slave does not push out at all, ( it stays bottomed out) press the clutch and it goes right back to where it was before, WHAT GIVES???
When you bleed it, you must force the plunger BACK INTO the sleeve before you attempt the next bleed. Connect it to the shift fork so the pressure of the fork pushes it back into bottom of the sleeve.
Jim
