  #32 (permalink)
Old 04-13-2010, 10:15 AM
dlotz dlotz is offline
Originally Posted by Jerry Clayton View Post
Dlotz---
I certainly hope that the reason your radiator cap leaks is that you simply don't know how to twist it and not your correct vintage heads leaking
Jerry
Jerry
You will be happy to know that the radiator cap was not the correct cap for the expansion tank in the end. The supplier sent me the incorrect cap, labeled as the correct cap, which is why I posted here to verrify it was indeed the correct cap (by part number) or not.
And thank you for pointing out the email date, I corerect that too so as not to confuse you with an email that was 5 days out of order.
Out of all the posts about the heads only you and one other guy mentioned that the heads wouldn't be an issue. And even the other guy said that it wasn't ideal, but useable. So there you have it "all the advice I ignored about the heads being ok" were from you and one other guy.
