Old 04-13-2010, 02:28 PM
psychoSEAL psychoSEAL is offline
Cobra Make, Engine: 351 Windsor
I found the problem(s) with the speedometer cable. While turning the cable from the trans end the speedometer does move. The problem is the gear at the trans end has some how fallen off into the trans. I have a C4 trans in the car. Is there a way to fish the gear out of the trans? If left laying in the bottom of the trans, will it damage anything? I have a cross member that is welded in not bolted. The trans guy told me there were 2 options. 1. Remove the tail section of the trans and fish out the gear. 2. Try to see what gear (color) that has fallen off into the trans and replace with a new one leaving the old one in the bottom of the trans. I dont know how the gear fell off because I didn't pull on the cable when I was working with the speedometer. Any ideas on the fix? THANKS!
