  #47 (permalink)
Old 04-14-2010, 01:45 AM
blykins blykins is offline
Originally Posted by mpanten View Post
I really wish someone would post the correct answer to this one. I have almost the exact same problem. I am using the pull type set up f. Fully extended the rod coming out of the slave is 3 and 3/8 inches. Fine and dandy I can adjust the with the proper clearence and the clutch works. the problem is that after the slave is actuated the rod will only extend about 2 1/2 inches and the bearing is riding. It does this hooked to the fork or not hooked to it does not matter. Im am going insane trying to get this thing to work. Im about ready to switch to a cable set up
Mark, I think your case would necessitate a return spring. If the slave cylinder isn't extending back to full stroke, then you'll probably need to help it.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
