Old 04-14-2010, 11:53 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
The inlet valves are NOT OPENED by fuel pressure!!!Gravity causes the float to drop, opening the needle seat. With larger diameter needle/seat assys, too much pressure will force them to leak overrunning the carb at the vents.
Also--too much volume/pressure can cause a carb to syphon fuel thru the vent at higher engine rpm.
I like to set carbs up with around 3 1/2 to 4 1/2 pressure and reasonable needle valve assy for the type of driving the car sees.
