Old 12-31-2001, 04:53 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
The bad news is, you'll have to drop the oil pan, and oil pump and install the pump drive shaft in the pump. Then bolt the pump back in, then the oil pan. If you plan on "running" this motor any, use a heavy duty shaft, SVO or equivalent; not a stocker, and definately not the original one you took out of the motor.
The good news is, you won't have to do this from under the car if you accidentially drop the shaft into the oil pan trying to install it, or it slips while removing the distributor. And you'll always remember to install the pump drive shaft with the pump on any motor you build in the future (won't you). Little lessons we all have to learn the hard way.
Another tip if you tear up the pan gasket while doing this. Cement the gasket to the block. Welwood or DAP contact adhesive works good on this. Then use wheel bearing grease to seal the pan to the gasket. Seals the oil in, but comes apart if you need to drop the pan for anything leaving the gasket intact and reuseable. Works for valve covers too. Makes vacuum tight seals on carb gaskets as well.
