Old 04-14-2010, 05:57 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
When you remove an AMP meter, you must permanently and securely connect the 2 wires originally on the back of the AMP meter together. All of the power must be routed thru an AMP meter to get a correct reading so those two wires are the main feed for the entire cars electrical users...There is also a master fuse on the drop down fuse panel. BTW...Your car is not wired to safely use a 140 Amp Alternator....Unless they have changed something I don't know about.
SPFWiringDiagrams@Comcast.net
