Old 12-31-2001, 07:19 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Moi?? Nawww.
You have the carb off for a little tweaking and forget to stuff a rag into the intake. Ever drop one of those little ball check carb bearings down into the intake? Or a small nut, or socket? Or the distributor hold down bolt, or washer, or bracket down into the distributor hole?
You have the engine on a stand. The pan is on. You turn the engine over to bolt a head on and something drops, "Tink", "Tink" into the pan. You think, "Wait a minute, there's not supposed to be anything loose inside the pan".
Let's see...what other dumb and embarassing things have I done either being careless or trying to save time.
