Old 04-15-2010, 02:31 PM
RodKnock's Avatar
RodKnock RodKnock is offline
BTW, there's also a local ERA for sale asking $60,000. Not affliated.
http://sfbay.craigslist.org/nby/cto/1683402312.html
"The ERA 427 gives you the best of both worlds: an accurate and faithful reproduction from the outside and an improved design on the inside. The ERA designed suspension works with the strengthened chassis to produce both excellent handling and a smooth ride.
This labor of love was built in 1998. With New Tires and under 9500 miles this fine Cobra can take you on many roads and adventures.
• 427 Big Block Ford Engine
• Legally registered in California as 1998 Special Construction Vehicle
• Stainless Steel Sidepipes
• Motor built by Crowther racing
• MSD Ignition Parts
• Loaded with ERA options
• True 427 ERA SC Roller (ERA mounted the body, suspension, steering and brakes)
• All frame and suspension parts powder coated gloss black by ERA
• ERA optional independent Jaguar2:98 rear end with inboard brakes and rotors
• Richmond Gear 4+1 Manual Heavy-Duty Transmission
• ERA reproduction Shelby shifter
• ERA high performance driveshaft
• True six pin 15” Trigo wheels, safety wired polished spinners with custom engraved center cover
• BF Goodridge TA Radials R15-295 rears, R15-235 fronts"
