Old 04-16-2010, 10:28 AM
Kawika Kawika is offline
Cobra Make, Engine: CRII
Capt eddie I got my kit about the same time you did, and my trunk was so thin that the first time that I closed the trunk with a very light touch, it dented in . how I got around that was I drilled holes on the inside and filled it with a fiberglass layer to thicken it up, then had to build it back up with fiberglass bondo. if your trunk is as thin mine you might need to do this also. once again I would like to thank both you and dv for this thread it really helped me get mine done. Dave
