Old 04-16-2010, 10:43 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Hey Arthur you're pretty darn close. Remember if you're getting 1/4 on the diagonals that's actually only 1/8th as you split the difference. That seems a little high for the ground clearance, most I've seen run lower on the front end. Is the wheelbase good on both sides?
Is the wheel base good on both sides? Mick, I don't understand your question. Please explain further.
5 1/2" It may be a little high. My bell housing hangs almost an inch lower than the frame and I'm installing skid plates on the frame to prevent an impact on it. We have many speed bumps here in the city of Chicago. After I drive the car awhile, I may feel more comfortable lowering it if I've not made major contact. I've got needle thrust washers with custom machined thrust bushings on the coil-overs and that makes adjusting shocks/ride height a breeze.
Arthur
