Old 04-18-2010, 05:07 AM
nymathboy nymathboy is offline
Thanks for the reply.
As I look at the connections on the wiper motor..........
-The ground which runs perpendicular to the other four terminals is at the top. This male terminal is horizontal.
-The other four are underneath the negative ground. These male terminals are vertical in their placement.
So from what you're saying, to test the motor I should connect power to the other side (either bottem left or top left) to the positive side of the battery to test the motor?
I was going to try this but was afraid to blow the motor. These lucas motors are not cheap.
