Old 04-18-2010, 06:33 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Dangerous Doug View Post
Unless you're a structural engineer and calculate the size and type of timber required for the span and weight you're working with, don't do it. One of three things will happen: you'll get lucky; you'll get killed; or, you'll damage your engine.
Get a cherry picker. It will also allow you to move the engine around as needed as you put it into place.
I also used an engine leveler, which made the weight shift a lot easier. In fact, get an air rachet to use with the engine leveler, which is much easier than a manual rachet.
DD
Second that.
If you want a straight hoist, buy a gantry crane from harbor freight.
Otherwise use a cherry picker. I used one for my car, able to put the engine in without taking the hood off.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
