Thread: Engine Run-On
Old 04-21-2010, 05:53 AM
601HP 601HP is offline
I've experienced run-on several times over past years.
I usually have the initial timing set at about 15-16 degrees. Anything higher than that on my engine has contributed to run-on. When run-on set in, I dialed the timing back several degrees and was able to eliminate the problem.
David
