  #25 (permalink)
Old 04-21-2010, 06:49 AM
ford fanatic ford fanatic is offline
Cobra Make, Engine: CRII 427 all alum small block
Default Epoxy floor
I did my 30 x60 shop 7 years ago with 2 part rustoleum then topped with a clear that I got from local concrete supply house.This is a work shop in IL that gets winter crap brought in No issues at all great floor but, I prepped it very carefully with muratic acid (twice) and powerwashed it 3 times. I did another building I own and didn't take the time on Prep and it is coming up in sheets. So I learned a valuable lesson. The first floor I did was 15 years old when I did it. I have since
(3 yrs ago) did 2 larger areas (5,000 sq ft ) professionally and had great results.
The pro's told me about 50% of their work was removeing old epoxy systems that weren't prepped right. My work shop has been welded above torch plassma cutter you name it and just sweep up. Power wash every spring to get out winter garbage.
