Old 04-22-2010, 05:49 PM
wetdog wetdog is offline
Cobra Make, Engine: classic roadster,408cu
Epoxy ...my garage should be a test facility welding slag ,chemicals , dogs running and skidding with their nails, jacks being drug all over ...it can be slippery but if you add the sand it does not clean up as easily ..also dont use the colored flakes ,if you ever drop a set screw or small part its real simple to find witout all the visual clutter..WD
