I didn't see a size range but it could work. What i'm dealing with is a SEE tractor a Mercedes truck that the Army uses in many configureations. The boots(bellows) are around the front and rear enclosed drive shafts (torque tubes) where they meet the transfer case. Their manual only metsions the bellows when you're reconnecting the rear or front axle as if they were magically allready there. The small end of the bellows is the problem, stretching over the larger belled end, I managed the last one because I had a large, stronger, younger guy manage to stretch it first, then turn the bellows inside out, and wrestle (for me) it over the belled end and then turn it back right side out while on the smaller diameter of the shaft.
Mike H
