Old 04-24-2010, 05:12 PM
Bobcat Bobcat is offline
Why don`t you take that float bowl off and set the float visually ? Turn it upside down and set it so it approx. level . You can also check to see if the needle valve is sticking then .... or better yet , get a rebuild kit and use the Holley gauge that comes with it and set it visually first . You can also replace the needle valve then .
Good luck ,
Bob
