Old 04-25-2010, 06:34 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by saltshaker View Post
The needle seat must be bad , went over the carbs again and with a feeler gauge set all the buterflies with a .006 feeler gauge and then reset the float on the one bowl. restarted the motor, vacum is up to 15 inchs , motor is very rough and gas was comming out the center tube on the carb with the bad needle seat...lower'd float till that stoped and opened sight plug on fuel bowl..
no fuel and the motor now runs for a couple min's and stalls. step on the gas petal it restarts....I NEED HELP or a new set of carbs!
Jon
how close to PA are you there in NJ......
