Old 04-26-2010, 01:58 PM
gfridland gfridland is offline
Cobra Make, Engine: Midstates 427 Ford FE
Engine Factory built my engine (390FE) in 2004...after install, RM seal started to leak almost immediately. Not wanting to remove the engine and send it back to EF, I went to a pro shop to get a repair done. Leak slowed down...thought I had it fixed, Leak is back...
I examined the crank journal, no oil groves on seal surface. The crank is correct rotation, but may have been machined. Will have to try a rope seal next.
Engine runs well, however, I also ended up replacing the Edelbrock Carb with a Demon as well as MSD ignition vs the standard distributor.
Wouldn't say to stay away, but would send caution.
Hope it helps!
