Thread: Tauras fan
Old 04-27-2010, 04:19 AM
undy's Avatar
undy undy is offline
Originally Posted by MFE III View Post
This fan draws alot of juice, so I'd recommend not skimping on the wiring and relays.
Amen brutha...
As a result, I converted my 1 wire 140 amp alternator to a 3 wire to pick up another volt, volt and a half. I also ran #2 copper from the alternator to my buss bar. For the cooling fan's primary circuit wiring I ran #8 copper up to Hollister's shortened wiring harness.
With the engine idling, lights/accessories on and the hi speed fan running I'm getting 14.2 volts at the fan motor and alternator alike. Hollister's relay setup and alternator/wiring mods did the trick. ...now if I can figure a way to keep the engine from shedding a couple hundred RPMs at idle when I turn on the hi speed fan.
As I'd mentioned earlier, I'm running two different cooling fan sending units. (Hollister's deluxe kit) The first sending unit is rated at 180 deg and brings on the low speed fan. I have that sending unit mounted in my Tunnel Wedge intake, next to the coolant temp gauge's sending unit. The second sending unit is rated at 195 deg and when engine temps dictate it cuts power to the low speed fan circuit and brings on the F4 rated hi speed fan.
As MFE said, your electrical system better be up to the task.
Too many toys?? never!
