Old 04-28-2010, 06:44 AM
Barry_R Barry_R is offline
The restrictors I use are just pieces of aluminum stock turned to a "slip in" diameter, with a step to keep them from falling all the into the Edelbrock's oil feed hole. They have a drilled .060 hole through the center. Just slide them into place making sure that they are below the rocker stand pad and install your rocker system.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
