Old 04-28-2010, 05:51 AM
Jim Doak's Avatar
Jim Doak Jim Doak is offline
Cobra Make, Engine: FFR with a 345-horse 302 Crate Engine
Default Small Block Dual Qual Setup: PCV Valve Question
OK, here's a follow-up question on my dual quad project for my 302.
I've purchased a Blue Thunder intake from Carl's Ford Parts and after discussing with a few guys including the Holley tech line, two 450 cfm mechanical secondary carbs specfic for 2x4 installations.
Here's my question: The Holley carbs do not have provisions for a PCV value (no port). I want to continue to run a PCV valve and am trying to figure out the best way to do it. (My current setup has a PCV valve installed in the rear of my passenger side valve cover. The hose is then routed to a PCV port on my Holley 600 carb.)
Do I buy a PCV hose fitting and install it in one of my air cleaner base plates?
If so, can it be installed on the rear air cleaner (I've got Stelling and Hellings air cleaners on order) or should it be routed to the front (primary) carb?
Is there a more elegant solution than using the air cleaner base plate as the vacuum source?
Thanks.
Jim Doak
FFR 2117
