Old 04-28-2010, 07:34 AM
patrickt patrickt is offline
Originally Posted by wrench87 View Post
... I have the smith bros push rods with no oil holes, also i have the arp bolts and the erson bolts for the rockers what do you reccomend i use?.
Then use the Smith Bros. push rods, the ARP bolts and the Erson bolts. Seriously, 99% of the FEs that are on this forum do not have push rod oiling... and 99.99% of the FEs in the world don't have them. Plus, if you take the time to read the five thousand posts on the FE forum having to do with restrictor size, a lot of smart "old time" FE guys don't believe there's really that much of a difference between 60 and 90. Your Canton will hold plenty of oil, you're not going to burn up your needles in the Ersons, and you don't need more than 60 lbs. of oil pressure -- if that. Don't overstress, it'll be alright.
