Old 04-28-2010, 04:16 PM
SP01715's Avatar
SP01715 SP01715 is offline
Cobra Make, Engine: SPF1715, Roush Built 434 ci Stroker, Dart Block, Ported AFR 205 Heads... 561 hp / 547 tq, Former Roush Show Car, Completed and Prepped By Olthoff Racing.
Originally Posted by Goopie 18 View Post
I have a 2006 SPF with a Roush 427R. The power and torque is very impressive. I have 4500 miles on the engine with no problems. When shopping for my car I drove 3 SPF's with the Roush, Shelby aluminum 427, and 427 FE side oiler. The heat from the last two was unbearable.The Roush never overheats in hot Florida weather. Living in South Florida ,The engine heat would have been a problem. I do notice that the Roush does not like approaching a stop sign at low speeds. I put the car in neutral and coast to the stop sign as I brake.
My car used to have the same problem. I replaced the carb with a 4150 hp with billet metering blocks, and had a guy that has worked on a lot of Roush motors dial it in, and the motor does not do that anymore.
Can't go wrong with a 427R / SR...
