Old 04-29-2010, 02:09 PM
Black Mamba's Avatar
Black Mamba Black Mamba is offline
Cobra Make, Engine: Contemporary Motors, 351W, Richmond T-10 4 speed,
Originally Posted by Calbullet View Post
BM, most Smiths gauges are mechanical and not electrical, this means there is not a electric sender to ground. the Smiths gauges have a solid connection between the gauge and the sender at the end of the line. to check the gauge you will have to put the sender in a pan or cup of hot water to check
OK, looks like I'm stuck again then. If I put the sender in hot water it's effectively like leaving it mounted where it is as I'm sure the oil is warming nicely while I drive. How do I tell which is defective otherwise?
